August 19, 2020 at 2:40 pm
ALEXANDRE COSTA
SubscriberHi All
Can anybody share some ideas about decreasing the peak values of continuity residual for a transient simulation ?
It is going like the picture :
August 19, 2020 at 3:23 pmRob
Forum ModeratorHow many iterations are you needing per time step? Aim to converge a step in 10-15 iterations. nAugust 20, 2020 at 12:30 pmAugust 20, 2020 at 1:41 pmDrAmine
Ansys EmployeeIt looks like you are using Windkessel ACT?n Now it is hard to say what can be done here: I will first check mesh, boundaries if all is consistent and try using smaller time step size. Does it diverge without using that Windkessel Model?nAugust 26, 2020 at 2:23 pmALEXANDRE COSTA
SubscriberHi DrAminenThanks for the output.nIf I replace for a simple pressure outlet, it goes. Unfortunatelly, I should use windkessel for a more realistic simulation.
n
August 26, 2020 at 4:25 pmDrAmine
Ansys EmployeeYou might need to add more relaxation and/or adjusting the windkessel UDF's. You might code that on your own using your own UDF or some expressions.n-
November 18, 2022 at 8:56 am
pen m
SubscriberHello, you have the code of the Windkessel model. There are some problems in the code I wrote. If possible, please send it to my email 972539894@qq.com, thank you.
Viewing 5 reply threads- The topic ‘Decreasing transient continuity residual peak value’ is closed to new replies.
5274
1859
1398
1257
