Decide volume to simulate an object
    • AskandLearn
      HinIs it possible to enter a specific volume inside an object in Ansys and use this volume to simulate using CFX?.n
      I'm not sure what you mean. We can extract a single region (geometry) from a larger assembly and having meshed just that can simulate it. So, for example, we can extract a valve and short length of pipe from a larger network to focus on the valve. n
    • AskandLearn
      I want to simulate the heat transfer inside a container with respectively, 10 mL, 20 mL and 30 mL. How can specify the volumes inside the container and be sure they are exactly 10 mL, 20 mL and 30 mL?n
      You can do this in the geometry tool, just label them before moving to meshing. Just make the volume at the size(s) required. n
    • AskandLearn
      It is not easy to decide at which height I exactly I can get the different volume. Can I use a tool to tell the exact volume or should I visually do a couple of tries? n
Viewing 4 reply threads
  • The topic ‘Decide volume to simulate an object’ is closed to new replies.
