October 18, 2025 at 11:57 am
Lumko
SubscriberGood day,
I am trying to model the flow of water that is pumped out of a tank by a submersible pump through a direct coupled discharge pipe.
When trying to generate the surface mesh, Fluent splits the discharge pipe, and the fluid zone in the pipe, into three domains that are dead zones. I am not sure why it does this. Could you kindly advise on its cause and solution?
------------------------- --------------------- -------------------- ---------------- ----------name skewed-cells (> 0.80) averaged-skewness maximum-skewness face count------------------------- --------------------- -------------------- ---------------- ----------outlet_pipe 0 0.01494663 0.49299298 53250sump_fluid 0 0.014004151 0.79789778 55244dead1-outlet 0 0.014314581 0.49299298 27304dead2-pipe_exterior 0 0.018713448 0.79789778 35734dead0-sump_fluid:1 0 0.017121627 0.42576109 19758pump_flow 0 0.014564433 0.48229695 17618pump 0 0.01100951 0.48229695 40504------------------------- --------------------- -------------------- ---------------- ----------name skewed-cells (> 0.80) averaged-skewness maximum-skewness face count------------------------- --------------------- -------------------- ---------------- ----------fff 0 0.014714286 0.79789778 144896---------------- After Surface mesh, the model consists of 4 fluid/solid regions and 3 voids.---------------- Surface Meshing of FFF complete in 0.84 minutes, with a maximum skewness of 0.80.---- Warning--- During Surface mesh, failed faces were identified and automatically repaired.Thanks and regards,
Lumko
Viewing 0 reply threads
- affinity not set
1487
1318
1156
