March 22, 2024 at 5:17 pm
Karim Rafiki
SubscriberHello,Â
Is it possible to perform port de-embedding in Ansys Circuit like in HFSS with a wave port or a lumped port ?
For example, I apply a 3 mm de-embedding on port 1 in HFSS, and I want to do the same thing but in Circuit
Thank you in advance for your responses
March 25, 2024 at 1:11 pm
Dan Dvorscak
Ansys EmployeeNot like that on arbitrarty s-parameters. In Circuit, if have the s-parameters of a fixture and a full device under test, you can utialize the "use recirpricol" options to de-embed the fixture from the DUT in a LNA simulation. But that is different than de-embbeding a fixed distince from a wave port. You can make that work, if it is a dynamically linked HFSS project and if you make the demebeeding distance a parameter. In that case, you would be able to change the de-embedded distance by changing that parameter in the Circuit component for the HFSS model.Â
Best regards,
-Dan
March 25, 2024 at 3:27 pm
Karim Rafiki
SubscriberThanks you for response Dan, I have an other question when I disable de-embedding in HFSS, the results in circuit do not change althought normally it is post-prcoessing
Best regards,
Karim
March 25, 2024 at 3:40 pm
Dan Dvorscak
Ansys EmployeeI'm not sure why that might be happening. I would expect the circuit results to change. Have you tried using the "refresh link" right mouse click option for the HFSS compoinent in the schematic?Â
March 25, 2024 at 4:30 pm
Karim Rafiki
SubscriberYes the results change, thanks you but I tried to put the de-embedding distance as a parameter but Ansys Circuit does not detect this parameter dynamically because it's post processingÂ
April 4, 2024 at 4:03 pm
David Prestaux
- The topic ‘De-embedding port in Ansys Circuit’ is closed to new replies.
5824
