April 22, 2020 at 4:04 pm
medhavi
SubscriberHow do I incorporate initial bed height (static bed height) in a spouted/fluidized bed column, using DDPM model with DEM collisions?Â
I have attached a picture from a research paper for reference.
April 22, 2020 at 5:41 pm
DrAmine
Ansys Employeeyou use a volumetric injection or inject from a plane in the domain inject the particles let them settle down then activate flow. -
April 24, 2020 at 6:37 am
medhavi
SubscriberThanks for the reply.
Can you please share any tutorial/reference, if you are aware of any such, for defining these injections?Â
Medhavi.
April 24, 2020 at 11:01 am
DrAmine
Ansys EmployeeI am sorry I do not have any tutorials to share. Probably you will find examples on the Customer Portal if you have access. There is no magic here: You inject the particle mass required and let them settle down in the column. After that you start with gas flow into the bed. The documentation does talk about volume and surface injection.
April 27, 2020 at 7:40 am
medhavi
SubscriberThank you.
May 6, 2020 at 2:17 pm
May 6, 2020 at 5:09 pm
DrAmine
Ansys EmployeeUse volume injection and fill the domain let the particles settle down. You can mathematically make rough estimate about number of parcels being injected to reach the required height. Similar can be gone by continuously injecting from surface till the dominant is filled. Do not solve flow in both cases. -
May 6, 2020 at 6:32 pm
medhavi
SubscriberAlright, thanks!
I will try it.
May 7, 2020 at 6:16 am
DrAmine
Ansys EmployeeWelcome! If you have access to the portal or your supervisor you might find there a tutorial /example for that.Â
- The topic ‘DDPM Modeling with DEM Collisions’ is closed to new replies.
6860
1343
1152
