October 28, 2019 at 1:02 pm
h395523899
Subscriber -
October 28, 2019 at 1:55 pm
Forum ModeratorCan you elaborate on "goes wrong"?Â
October 28, 2019 at 1:57 pm
October 28, 2019 at 4:22 pm
DrAmine
Ansys EmployeeTry to start conservative and use algebraic granular fluctuation -
October 29, 2019 at 9:47 am
October 29, 2019 at 4:45 pm
DrAmine
Ansys EmployeeYes. Euler Granular might be a cheaper alternative.
Ensure that on start you are not at the friction limit. -
October 30, 2019 at 9:59 am
October 30, 2019 at 10:13 am
DrAmine
Ansys EmployeeCan you try with smaller particle time step size?
October 30, 2019 at 12:39 pm
h395523899
SubscriberAs shown in the figure, do you mean that the parameter at mark 1 is adjusted?
My understanding of the two markers marked is:
1 represents the number of iterations of the particle phase on each fluid iteration step
2 indicates the time step of particle injection
I don't know if my understanding is right.
October 30, 2019 at 1:41 pm
DrAmine
Ansys EmployeeSettings 2 to use smaller particle time step size than the flow time step size. By the way have you tried using Euler Granular instead of DDPM? That is what I recommend especially if you are near packing limit and particles have single size.
October 30, 2019 at 2:10 pm
h395523899
SubscriberI have used Euler Granular before, but I didn't get the results I wanted.
My aim is to simulate water carrying sand.
No sand water and sand water are alternately injected. But the simulation result is that the sand is piled up together. The actual situation in the model should be a section of sand, a section of no sand.
October 30, 2019 at 2:27 pm
DrAmine
Ansys EmployeeGood Luck.
- The topic ‘DDPM model always reports an error’ is closed to new replies.
3497
1057
1051
976
942
