August 27, 2023 at 3:06 pm
Yossi Abutbul
Subscriberis it possible to obtain voltage drop in q3d?
August 29, 2023 at 8:09 am
Sriparna De
Ansys EmployeeHi Yossi,
You can see several field plots in Q3D. Directly you cannot plot the voltage drop in Q3D. You can edit current sources to compute voltage drop using the Resistance Matrix which you get from Q3D. For better understanding, Please refer to Resistance Matrix in the Technical Note of Q3D Extractor Help (ansys.com)
- The topic ‘DC voltage drop in Q3D’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1482
