March 10, 2020 at 5:25 am
johnfides
SubscriberHi,
   I made a very simple example in ansys maxwell and want to calculate the I ^ 2xR loss of the copper bar you see in the figure. I selected eddy current as the solver and made a current exciation. I looked at ohmic loss. However, I could not find the values I calculated. In addition, as the size of the region I throw out of my bar changes, ohmic loss changes. What is the reason for this and how can I correctly calculate ohmic loss in this bar?
Thank you for your help.
March 10, 2020 at 9:24 am
johnfides
SubscriberHi,
Thank you for your help but I am using ansys maxwell 2015 version. Can't I do it right with this version? By the way, my conductor in reality is not the litz.
Thanks again.
March 11, 2020 at 5:30 am
johnfides
Thanks again.
- The topic ‘DC loss on the bar’ is closed to new replies.
- Ansys Maxwell 3D – eddy current
- Plotting Ex, Ey and Ez in vector forms individually
- Maxwell circuit – PWM
- Compute near field simulation with current
- Ansys-MATLAB Co-Simulation
- Simplorer+Maxwell Cosimulation results and Maxwell results mismatch
- Y wiring method and the start and end points of winding.
- Ansys Resonance simulatioin error
- How does Ansys Twin Builder implement different simulation steps for subcircuits
- Calculating E-field tangential to a 2D resonant structure on a sapphire chip
2422
930
599
591
569
