November 30, 2023 at 7:18 pm
Esteban Moreno
SubscriberI'm having an issue where before I run my calculation in the Fluent Solver, I select some additional variables to use in CFD Post. However, these additional variables don't show up in CFD Post when I need them to make charts for example. Any help is appreciated and I attached a couple screenshots to help give more context.
December 1, 2023 at 7:50 am
SRP
Ansys EmployeeHi,
You can try to export variables using cdat file: file > export > solution data then change the file type to cdat for cfd post and ensight.
Hope this helps.
Thank you.
December 11, 2023 at 11:09 pm
Esteban Moreno
SubscriberThank you for the help, it worked
- The topic ‘“Data File Quantities” do not show up in CFD Post’ is closed to new replies.
1885
1404
1303
