dasac failure at temperature
    • Stemphanie_anansu
      I calculated the EDC model, first calculated the initial field using the finite rate ED model, then converted to the EDC model.
      After converting to the EDC model, it reported an error, and the inlet reported the same error using both the velocity inlet and the mass inlet.
      What is the reason for this? What should I do to solve it?
      Have a look in the AIS Search, at the top of the page.
  • The topic ‘dasac failure at temperature’ is closed to new replies.
