October 25, 2023 at 8:40 am
October 25, 2023 at 10:58 am
Akshay Maniyar
Ansys EmployeeHi Murali,
Please check the below AIC course for more details on damping.
Damping | Ansys Innovation Courses
Thanks,
Akshay maniyar
October 25, 2023 at 11:29 am
murali
SubscriberHi, I had watched the video. While doing MSUP analysis there is an option to give damping ratio directly in the damping control. But while doing full transient analysis, that option is not there. There is a dropdown with damping vs frequency. Will it be enough to enter the value there?
October 27, 2023 at 11:15 am
murali
SubscriberIn the damping vs frequency option, what frequency should i enter??
October 27, 2023 at 12:26 pm
Rahul Kumbhar
Ansys EmployeeYou need to input the structural damping coefficient for stiffness matrix or mass matrix or both. Whereas Damping ratio is ratio of system damping to the critical damping. Generally Structural Damping Coefficient = 2 x Damping Ratio.
October 27, 2023 at 5:27 pm
murali
SubscriberHi, all I have for the problem is the damping ratio 0.01. I need to do transient analysis on a beam. My doubt is how do I find out the stiffness and mass coefficient from the damping ratio value that I have. On the other hand, in the option damping vs Freq, I am supposed to enter frequency along with the damping ratio. What frequency should I enter?? Is it the natural frequency??
October 30, 2023 at 8:48 am
murali
SubscriberAny help would be appreciated.
October 30, 2023 at 9:08 am
ErKo
Ansys EmployeeHi
This is a very good discussion:
/forum/forums/topic/material-damping-and-modal-analysis/
All the best
Erik
October 30, 2023 at 9:20 am
murali
SubscriberÂ
Hi Erik,
I had seen this discussion as well. I have a confusion as to what value of frequency we need to give with the damping ratio.Â
What I am trying to do here is to find the transient response of a cantilever beam to an intitial displacement. I need to find out the reponse of the beam to different damping scenarios. I have a set of damping ratios (coulomb damping) obtained experimentally. I am tryuing to simulate the condition. So need to conduct thze anlysis for different damping values.Â
October 30, 2023 at 9:30 am
ErKo
Ansys EmployeeÂ
See that discussion Peteroznewman explains what Ansys does when you give a frequency of interest (say the freq. of your dominant mode of interest that will be excited – frequency_given) and a damping ratio (damp_ratio_given).
As he says, it calculatesÂ
beta = (2*damp_ratio_given)/(2*PI*frequency_given).You can check that in Ansys yourself, by giving freq. = 20 Hz, damping ratio = 0.01, then Ansys will give a beta as =
0.000159 All the best, and perhaps some other forum members can give some more feedback, but the post and this should explain (also see some more material on the internet about Rayleigh damping.
Erik
October 30, 2023 at 9:32 am
October 30, 2023 at 9:35 am
ErKo
Ansys EmployeeSee that discussion Peteroznewman explains what Ansys does when you give a frequency of interest (say the freq. of your dominant mode of interest that will be excited – frequency_given) and a damping ratio (damp_ratio_given).
beta = (2*damp_ratio_given)/(2*PI*frequency_given).So if you want a damping ratio of 0.01 at your frequency of interest (say 20 Hz) that are the values you put in. So beta will give you then 0.01 damping at 20 Hz that all the equation says.
October 30, 2023 at 9:53 am
murali
SubscriberClear. Thanks a lot.
October 30, 2023 at 9:54 am
ErKo
Ansys EmployeeGlad we could help.
Erik
- The topic ‘Damping in transient analysis’ is closed to new replies.
6760
1330
1097
