August 7, 2023 at 4:49 pm
Maryam Tabbakhh
SubscriberHi,
I was reviewing the example for SSI in here:
https://ftp.lstc.com/anonymous/outgoing/ubasu/website/examples/ssi-transient.k
I had two questions? Why the coefficeint of hourglass is zero?Â
and the second question is that:Â
why there is no tag for part in Damping_frequency_deform? If we put the coefficient to zero does it apply to all?
Best
August 9, 2023 at 9:48 pm
Ushnish Basu
Ansys EmployeeIn general, an entry of zero sets the default value as listed in the manual.
DAMPING_FREQUENCY_RANGE applies to all parts for PSID=0, except for those specified in other DAMPING_FREQUENCY_RANGE cards. This is mentioned in the description in the manual.
Note that these examples are illustrative only, and you should set parameters as appropriate for your model
- The topic ‘damping and hourglass coefficient in SSI example’ is closed to new replies.
5014
1681
1387
1248
