April 22, 2024 at 12:19 am
Chenxi Zhang
SubscriberHi,
I loaded a .ldf file of a farfield simulation from FDTD to MODE and tried to overlap it with a gaussian beam. Here are the error messages:Â
z1 = loaddata("z1");
::monitor  ::monitor_1  ::scat_ff::z1  ::scat_ff::z2  ::scat_ff::x1  ::scat_ff::x2  ::scat_ff::y1  ::scat_ff::y2  ::scat_ff::index  ::source
overlap("z1","gaussian1");
Error: prompt line 1: in overlap, no d-card called: z1 was found
overlap(z1,"gaussian1");
Error: prompt line 1: the first 2 arguments of overlap must be stringsIn the D-card window I see that d-card 4 has name z1, but here it says z1 is not found. I tried ?getdata and get the following message:
::gaussian1
::monitor
::monitor_1
::scat_ff::z1
::scat_ff::z2
::scat_ff::x1
::scat_ff::x2
::scat_ff::y1
::scat_ff::y2
::scat_ff::index
::sourceSo I also tried names "::scat_ff::z1" and "scat_ff::z1". Both were not found.Â
I would like to know why and how can I get the correct name of a d-card. Thanks.
April 22, 2024 at 5:16 pm
Amrita Pati
Ansys EmployeeHi Chenxi,
If you haven't already, could you try running the following and let me know if the issue still persists:
ol = overlap("::gaussian1","::scat_ff::z1"); #Both d-cards (with the colons) within double quotesÂReagrds,
AmritaÂ
April 22, 2024 at 9:52 pm
Chenxi Zhang
SubscriberHi Amrita,Â
Thanks for your reply.
Here's what i got:
ol = overlap("::gaussian1","::scat_ff::z1");ÂError: prompt line 1: in overlap, no d-card called: ::scat_ff::z1 was foundÂÂ -
April 22, 2024 at 9:54 pm
Amrita Pati
Thanks for letting me know! Let me test somthing very similar and get back to you.
Amrita -
April 22, 2024 at 10:44 pm
Amrita Pati
These commands would work given that certain conditions are satisfied:
- The FDE plane (in which the Gaussian Beam is created) is same as the monitor plane. Here if the monitor and FDE are both z-normal, then the overlap script command should work. But if they are not in the same plane, you will get this error message.
- The wavelength at which the FDTD monitor data is generated must be the same as the wavelength of the Gaussian Beam.
- The size of the monitor and the size of the FDE region used to create the Gaussian beam must also be the same.
If these three conditions are satisfied, you should get the result as expected.
Please let me know if you continue to face issues.
Amrita -
April 26, 2024 at 8:47 pm
Chenxi Zhang
Thank you again for your reply.Â
I think I've already satisfied these conditions but the same error message still appears.Â
The set-up of my FDTD simulation includes only an electrical dipole and a DFT monitor. I've set both the source and target wavelength to be 1.55 microns(the same as the default gaussian beam wavelength). And both the FDE plane and the monitor plane are z-normal(x span from 0 to 4, y span from 0 to 4). Are there any simulation steps I am missing here?
Chenxi
April 26, 2024 at 8:57 pm
Amrita Pati
Thanks for sharing more information! I can't really think of any other reason. But let me spend some more time on this and come back to you.Â
Out of curiosity, do you aim to take the FDTD results from the DFT monitor (called "monitor") or one of the monitors inside the analysis group (called "scat_ff")? Secondly, I believe this screenshot was taken after the simulation was done running. But I am wondering why there is no data in the monitor, but there is data in the analysis group.
Amrita -
April 26, 2024 at 9:42 pm
Chenxi Zhang
SubscriberOh your response is so inspiring! I didn't realize before that I wasn't logging data in my monitor. Once I changed the plane from z=0 to z=0.5 I was able to successfully overlap the monitor data with the Gaussian beam. Thank you so much for your help.
I still have a question about this. I'm still wondering why could I overlap the monitor data with gaussian beam but could not using the "z2" monitor inside the analysis group, even if they are exactly the same plane. Â
April 26, 2024 at 9:59 pm
Amrita Pati
Ansys EmployeeYou are welcome, Chenxi!
If you edit the analysis group, then go to Analysis--Variables, there should be a variable called "target wavelength", is there any chance that this value is set to something other than 1.55 um:
If yes, I would recommend changing it to 1.55 um and then recalculating the overlap. If it is already 1.55, let me know, I will try to think if there is any other reason that this could be happening.
Amrita -
April 26, 2024 at 10:01 pm
May 2, 2024 at 7:49 pm
Chenxi Zhang
- The topic ‘D-card name mismatch’ is closed to new replies.
