November 8, 2018 at 7:10 pm
KPS1984
SubscriberHi all, I have done analysis in torsion of solid shaft. Axis of shaft in Z direction, For my analysis I have used two boundary condition, the BC's are 1. Fixed at one end, 2. Cylindrical support by selecting surface shaft( tangential (free), radial (fixed) and axial (fixed).. only rotation is allowed.
I got some results.
If I do the same analysis by LINE BODY method instead of solidshaft, I am not able to constraint the cylindrical support. So I used fixed rotation constraint. But the results are different for the same analysis.
Kindly give me a idea to make cylindrical support constraint in line body method. Thank u.. -
November 9, 2018 at 1:59 am
Sandeep Medikonda
- The topic ‘Cylindrical support of shaft’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
1487
