July 15, 2024 at 2:50 pm
July 15, 2024 at 3:43 pm
Forum ModeratorHow do you plan on post processing the effect of the various inlets on the small sector you're modelling?
July 15, 2024 at 4:13 pm
Zwernjayden
SubscriberSorry I didn't reply in the thread, but I'm interested in the wall temp and coolant temp
July 15, 2024 at 4:12 pm
Zwernjayden
SubscriberI’m mostly worried about taking the max walk temp and coolant temp
July 15, 2024 at 4:23 pm
Forum ModeratorWhich is the channel in the outer part?
July 15, 2024 at 4:38 pm
Zwernjayden
SubscriberThe copper colored part is the channel/chamber, and the green inside it is the coolant fluid domain. The big green triangle section is the combustion chamber fluid domain
July 16, 2024 at 9:09 am
Forum ModeratorOK. So can you assume an external HTC and model just the combustor? Then map the flux onto the channel model. Running two domains can be problematic, and unless you've run the model do you know how periodic the combustor actually is? Remember that opposing jets tend to interact in interesting and unexpected ways.
- The topic ‘Cyclic sectons at different periods’ is closed to new replies.
5779
