November 10, 2022 at 2:50 pm
Walter Otiniano
I've got some FEA structural results in Ansys Discovery and I would like to change the orientation of the cut plane, how do you do this?
November 11, 2022 at 1:05 am
Atharv Joshi
Forum ModeratorHi Walter Otiniano
After selecting "Cut Plane" option from the Result Arc, select the plane. Option to move/rotate will appear. Which you can use to view results in different planes.
I have attached a short video demonstrating the same.
Thanks and Regards
​ 🛈​ This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions​​
- The topic ‘Cut Plane’ is closed to new replies.
Ansys Innovation Space
1052
1051
896
877
