July 18, 2024 at 10:26 pm
sk02821
SubscriberI am working with the fluidization of non-spherical particles and need to modify the drag law in a custom module in Rocky. Could someone help me with creating and implementing this custom module?
July 19, 2024 at 12:43 pm
Forum ModeratorMost of that should be covered in the documentation, and there may even be examples in the API and modules sections.Â
How non-spherical are the particles, and do you have all of the drag v orientation data?
July 21, 2024 at 9:26 am
sk02821
SubscriberSome specific particles like ellipdoidal, cuboid, and cylinder.
July 22, 2024 at 10:10 am
Forum ModeratorI think they're available by default, check the options in Rocky. If you do some of the tutorials as a starting point see what shapes you can create.Â
July 22, 2024 at 10:45 am
sk02821
SubscriberI am able to creat the particles but I think I need to change in the drag coefficient in the module.
July 22, 2024 at 1:27 pm
Vinicius Daroz
Ansys EmployeeHello Salma,
Take a look at tutorial 23, available on Ansys' help page. You will find a step-by-step guide on how to install the SDK dependencies and compile your first module. After that, you can check the available examples on Ansys' customer portal. You will find a custom drag force module, that will serve you as a good starting point. Â
July 29, 2024 at 10:11 am
sk02821
SubscriberThank you so much for all the responces.
- The topic ‘Custom module’ is closed to new replies.
6104
