curves of residual stabilize after only two decades !
    • manelaero2020
      Hi everybody
      I am simulating an airflow into pipes. The initial value of residual (Momentum and continuity) starts from 0.01 and stabilize at 0.0001. Curves of mass flow at the inlets are stabilized, which means computation has converged.
      I am worried because :
      Residual has only moved from 0.01 until 0.0001 ( reduced only by 2 decades)
      What do you think about the reasons? Am I right to be worried?
      Thank you very much for your help
      NB: I am using fluent
    • Karthik Remella
      Administrator
      Hello:
      Please check your mass and energy balances (Hint: Fluxes under Reports). If these are acceptable and your monitors are flat, you should be fine. If they are not acceptable, then you have a problem.
      Karthik
    • manelaero2020
      Thank you
      The sum of inflow and outflow is 0.0001 kg/s, the total flow at the inlet is 0.145 kg/s and the sum of outflows is about 0.1449 kg/s
      This result is acceptable
      Best regards
    • Karthik Remella
      Administrator
      Sounds good!
  • The topic ‘curves of residual stabilize after only two decades !’ is closed to new replies.
