July 19, 2017 at 9:20 pm
ECEPSU
SubscriberWhen defining the electromagnetic condition "current" I think that AIM is actually using the value as current density!
When I enter 2 Mega Amps (yes 2,000,000 Amps) my simulation yields a current density of 15915816 Amps/m^2 in my copper vias. Yielding a total current of 2 Amps (should be 2,000,000 Amps). See my calculations and images below
# Of Copper vias: 4
Diameter of 1 Copper via = 200 um = 0.0002 m
Radius of 1 copper via = 0.0001 m
Area of 1 Copper via =Â 3.14159 * 0.0001*0.0001 =Â 0.0000000314159 m^2
 Current = current density * Total Area = 0.0000000314159 m^2 * 4 * 15915816 A/m^2 = 2 A
***NOT EQUIVALENT TO THE 2,000,000 AMPS I ENTERED****
Therefore you have to enter current density for a known surface area to define the current you want!
Either the units for the current need to be changed to Amps per unit area, or the calculation needs to change to allow the user to input desired current values!
Can anyone else validate this?
Defining current under electromagnetic conditions
July 20, 2017 at 9:31 pm
pgl
Ansys EmployeeI could be way off here, but in the final screenshot you can see the four cylindrical via volumes selected. The calculated current density is showing the min & max for the currently selected volumes. What happens if you change the location to the 4 areas of interest instead? Â Â
July 21, 2017 at 9:19 pm
July 21, 2017 at 9:47 pm
pgl
Ansys EmployeeYes that's exactly what I meant. O.K. Let's see if the rest of the Student Community can chime in here to help out. Â Â
- The topic ‘Current used in calculations as Current Density’ is closed to new replies.
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- 2D transient simulation -torque issue
- Two way coupling for Maxwell and thermal problem
4602
1510
1386
1209
