January 30, 2024 at 5:00 pm
shashankc
SubscriberI am trying to simulate a coil with air core and i keep getting error "current leak to the air".
I have changed the excitation to current density and current density terminal as per the previous suggestions. I have also modified the mesh settings to classic and assigned the feed to a 2D plane taken from the section of coil.
January 31, 2024 at 3:19 pm
Reshmi Raghavan
Ansys EmployeeHello Shashank,
Could you please share the snapshot of the coil.
January 31, 2024 at 3:27 pm
shashankc
SubscriberPlease find below, I have attched the coil. It is just an air core coil made of copper. If I have the feed section inside the coil (As shown in image below) then simulation runs for 2 adaptive passes and gives me "Current leak to air" error But if the feed section is outside the coil, the simulation is terminated immediatly with the same error message.Â
- The topic ‘Current leak to the air’ is closed to new replies.
5824
