May 13, 2021 at 9:42 am
Ichiro
Our two customers have an activation problem by Curl error (4) below. So, they are unable to use Discovery 2021R1.
 The message is "Curl Error (4) A requested feature, protocol or option was not found built-in in this libcurl due to a build-time decision. - Unsupported proxy 'https://username:password@proxy-server:8080', libcurl is built without the HTTPS-proxy support."
They set "HTTPS_PROXY" as system environment variable and "https://proxy server:8080" (one customer set "https://proxy server:8080" and another one set "https://username:password@proxy server:8080") as the value. They also added "ansysls_client.exe" in antivirus exception list and firewall.What should they do/check in next? Would you let me know?
I have received ".ansys" folder from one. So, I can send it to you. Thanks in advance,Â
  Ichiro -
May 17, 2021 at 3:08 am
Naresh Patre
Ansys EmployeeHello Ichiro
Can you please send all the files requested in section 6 of the troubleshooting document mentioned below, to ansys-discovery-support@ansys.com:
https://discoveryforum.ansys.com/t/q5gwjy/discovery-license-activation-troubleshooting
May 18, 2021 at 9:25 am
Ichiro
SubscriberHello Naresh Patre ,
I have sent the files of one customer to the email address.
And I will send the files of another customers after receive them, too.
 Thanks,
 Ichiro
May 26, 2021 at 8:01 am
Naresh Patre
Ansys EmployeeThe customer seems to be using a .pac file for their proxy configuration. We currently do not support this proxy method.
- The topic ‘Curl Error (4) in Discovery 2021R1’ is closed to new replies.
4858
1587
1386
1242
