Ansys Free Student Software
Critical Error during Installation
    • oshooaipe2020
      "The manifest file specified for this installation does not exist . Please verify that the install was run according to the documentation . File not found- uninst_data.dat"  This is what my ansys r2 2024 install is showing so i am not seeing the workbench
    • Mrunali Barde
      Hello oshooaipe2020,
      I believe it could be a faulty installation. Did you get a chance to reinstall applications or check if standalone applications are working?
      Are you using a student version or a commercial?
      Can you please try to install a fresh setup of fluids or structures package and let me know?
      Reinstall the application as administrator & delete configuration files:
        1. Uninstall Ansys package as administrator.
        2. Rename ‘ %temp%\.ansys’ to ‘‘ %temp%\.ansys.old’
        3. Rename ‘AppData\Roaming\Ansys’ to ‘AppData\Roaming\Ansys.old’
        4. Rename ‘Documents\Ansoft’ to ‘Documents\Ansoft.old’ (if any)
        5. Download then install the Ansys product-specific package as required as administrator.
      I hope this helps.
      Wishes,
      Mrunali.
    • oshooaipe2020
      I am using a student version... I would try these and get back to you...thanks
      I have tried reinstalling it thrice; it just takes up my storage and still shows the critical error
      I just discovered the installation is taking up my storage but the app is not installed just in the extracted folder
    • Mrunali Barde
      Reaching out to you over email.
      Wishes,
      Mrunali.
