October 31, 2023 at 2:48 pm
Muhammad Zeeshan
SubscriberHi there!
Can anyone please let me understand how we can get critical buckling moment of a beam with a mid point concentrated load?
I'm working on a project to first model a beam with a concentrated load & get critical moment from ansys and then verifying the answers with EC3 methodology. Later on, will do parametric study on the same beam in ansys.
Every literature i read just mentions the results of critical buckling moment (Mcr) but doesn't define how they got it particularly from ansys since ansys only tells you the load factor which one is supposed to multiply with the applied load to get critical buckling load but I'm looking to get critical moment?
#Question #Structure #Buckling #Mechanical -
November 1, 2023 at 2:21 pm
dlooman
Ansys EmployeeYou can apply the buckling factor times the mid-pt moment. Presumable that's Mcr. The moment could be calculated by hand or retrieved from the static analysis.
November 1, 2023 at 7:47 pm
Muhammad Zeeshan
SubscriberHi Dave!
Thanks a lot for your response. I did the same last night. Multiplying the load factor with the bending value from BMD. Don't have the idea to extract BMD or SFD for a solid in ansys hence generated them by hand because all the queries i went through, it says you can't get BMD values for a solid in ansys unless it's defined by a line body.
November 1, 2023 at 8:10 pm
dlooman
Ansys EmployeeSorry. I assumed the model was a beam model. Can you calculate the moment by hand?
November 1, 2023 at 8:12 pm
Muhammad Zeeshan
SubscriberYes I can. You got any idea whether we can develop the kind of BMD for a solid in ansys?
November 1, 2023 at 8:46 pm
dlooman
Ansys EmployeeNo, I'm afraid not.
November 2, 2023 at 7:34 am
ErKo
Ansys EmployeeHi
See if this helps (section forces and moments on 3D part bodies):
/forum/forums/topic/can-you-determine-the-resultant-force-when-using-section-planes/
All the best
Erik
November 2, 2023 at 1:59 pm
Muhammad Zeeshan
SubscriberThanks Erik. I'll definitely look into it.
- The topic ‘Critical Buckling Moment’ is closed to new replies.
5964
1307
