TAGGED: #fluent-#ansys, ansys-cfd, surface-temperature
May 15, 2024 at 7:22 pm
Gregory Harrington
SubscriberI am trying to create a user defined function to calculated adiabatic wall temperature on an airfoil surface. Adiabatic wall temperature is defined as Taw = Tstatic + Pr^1/3*(Ttotal - Tstatic) so the adiabatic wall temperature should not be lower than the static temperature.
I created the UDF and then created a contour of the UDF on the airfoil surface. The adiabatic wall temperature UDFÂ contour is several hundred degrees lower than the static temperature which was odd to me. I then made a UDF that is just the static temperature and plotted a contour of that. It should look identical to the static temperature contour but the UDF of static tempearture is also several hundred degrees lower than the static temperature. These two temperatures should be equal.
Am I doing something wrong in my implementation of UDFs?
May 16, 2024 at 1:46 pm
Forum ModeratorWhat wall boundary condition did you set? The example looks to be an expression, how are you linking the wall facet temperature to the adjacent cell temperature?Â
- The topic ‘Creating UDF but not obtaining expected result’ is closed to new replies.
4633
1540
1386
1225
