Creating S-N Curve without finding listed data
    • Alex Flasch
      I am working in Ansys worbench with the low expansion material FeNi41. I need to run fatigue and life options on this design that includes that material. However, I get the error that I need to gernerate an S-N curve. The issue is that the material properties are limited and the list does not include things like strength coefficent. Any suggestions for troublshooting?
    • danielshaw
      No. A S-N curve is required user input data for a StressLife fatigue analysis using the Mechanical Fatigue Tool (FT).  Mechanical cannot generate that curve.  To use the FT, you must obtain the S-N curve data for FeNi41 and define it in Engineering Data.
    • Yash Kathar
      From where could we get the sn curve
    • danielshaw
      The material supplier should be able to provide the material properties.
  • The topic ‘Creating S-N Curve without finding listed data’ is closed to new replies.
