October 24, 2020 at 6:18 am
Thomasta3
SubscriberHi,
I would like to capture the X-Y-Z directional deformations along the same angular displacement on a wheel. I have achieved this with creating quadrants in my CAD geometry and assembling them together, however I wonder if there is a way to do this easily within ANSYS. Below is my simulation geometry:
October 24, 2020 at 2:38 pmpeteroznewman
SubscribernI don't know about lines, but you can easily create a plane at any angle by adding a coordinate system, rotated to the desired angle. Then create Construction Geometry and select that coordinate system to make a plane. Now you can plot directional deformation on that plane in that coordinate system for the cross-section of your mesh that is cut by that plane.nOctober 30, 2020 at 2:50 amThomasta3
SubscriberHi Peter,nThanks for your response. That sounds like a good solution, and I'll give it a shot!nViewing 2 reply threads- The topic ‘Creating Lines Of Solution Along Cylindical body’ is closed to new replies.
3029
971
858
836
777
