Creating FSI interface on complex geometry
    • Aslamucf
    • RK
      Hello, nAnsys employees will not be able to download the files. Can you please insert an image instead so that we can assist you better? Thanks. n
    • Aslamucf
      Hello, These are the attached picturesnnn
    • Karthik Remella
      Administrator
      Hello,nYou might have to reconstruct some of the end region to be able to cap these. Is this an STL file? If so, I'd start with using the skin surface tool to create surfaces which you can use for your simulation. You should be able to find this tool in SpaceClaim. Here is some information and tutorials that can help.nThank you! nKarthiknn
  • The topic ‘Creating FSI interface on complex geometry’ is closed to new replies.
