June 8, 2023 at 3:11 pm
Shyam Prasad V Atri
Subscriberwhen i use the tui command
mesh/modify-zones/make-periodic
wall1
wall2
how would I know if it created a conformal periodic or not? is there any way to cross-check?
June 8, 2023 at 8:06 pm
Federico
Ansys EmployeeYou should create periodic zones before bringing your mesh into Fluent Solution mode to ensure it is conformal.
For example, if you use the Watertight Geometry workflow in Fluent Meshing: 3.6. Setting Up Periodic Boundaries (ansys.com)
June 8, 2023 at 8:34 pm
Shyam Prasad V Atri
SubscriberI see..but I have already created the models and i am doing this
I have many models for which i have to create periodic boundaries so i can't go ahead and change all the mesh now. is it possible to do this with TUI?
when i use this commandÂ
i get an option to pick translation or rotation and give distance vector but i did not see the option of conformal or nonconformal coming up on the console when I used the TUI command.
June 8, 2023 at 8:47 pm
Federico
Ansys EmployeeI just ran a test on my end and I am unable to make periodic zones using the TUI command if the number of elements do not match between the 2 zones. Additionally, creating a non-conformal periodic zone will create a Mesh interface. So perhaps there lies your cross-checking.
I invite you to try this, if you do not have a Mesh interface after creation of the periodic zone, it would suggest that the 2 boundaries are conformal.
June 8, 2023 at 8:52 pm
Federico
Ansys EmployeeActually, you can use this command insteadÂ
/mesh/modify-zones/create-periodic-interface
This command gives you the option for Conformal/Non-Conformal
June 13, 2023 at 11:32 pm
Shyam Prasad V Atri
Subscriber/mesh/modify-zones/create-periodic-interface command worked.
Thank you so much for suggesting this.
June 14, 2023 at 12:02 pm
Federico
Ansys EmployeeHappy to help! :)
- The topic ‘creating conformal periodic boundary’ is closed to new replies.
5809
