January 30, 2026 at 2:52 am
scabo
SubscriberHi
I am running an unstedy Fluent simulation on HPC and trying to create an animation of particle positions via the command /solve/animate/objects create anim animate-on particle-tracks-1 storage-type hsf. It is creating the animation object but I cannot play it while I load the dat file back into Fluent. Also it is not writing any .cxa file in the dir. Is it not possible to create animations while running on HPC?
thanks
January 30, 2026 at 8:30 am
SRP
Ansys EmployeeHi,
When running Fluent on HPC, you need to use the commands, please check user's guide here:Â 4.1. Starting Ansys Fluent-
January 30, 2026 at 4:44 pm
scabo
SubscriberHi-this link is not opening, demanding a lot of things via a form. Btw i have used the command written in my message above-is it something different you are talking about?
5009
1681
1387
1248
