Preprocessing
Preprocessing
Creating a Surface from a Curve
    • Kyu
      Greetings.
      I wish to, in the following image, create a surface between the inner shape in green, and the outer circle:
    • Kyu
      I decided to try, 'Sketch Projection' after seeing it a lot, but that is just awful. It's no where close to the original geometryn
      nExtrude a solid body of the inner shape so that it is both above and below the plane of the circle.nCreate a surface from sketch of the circle so you have a surface.nUse Boolean Subtract on the surface and use the inner shape as a tool.n
    • Kyu
      @peteroznewmannWorked like a charm, thank you (:n
  • The topic ‘Creating a Surface from a Curve’ is closed to new replies.
