July 14, 2025 at 3:14 pm
July 15, 2025 at 12:17 pm
Chinmay T
Forum ModeratorHello,
Please ensure that the port geometry is correctly defined and that it does not intersecting with any other objects or faces and port is exactly toching to the conductor.
Also make sure that that the materials on either side of the port are correctly assigned and that they are set to solve inside. This can be done by selecting the object and checking the "Solve Inside" option in the Properties window.
Thank you,
Chinmay -
July 15, 2025 at 11:29 pm
Takeshi Itadani
Ansys EmployeeThe Wave Port must be placed on the boundary surface of the analysis space. The error message displayed indicates that both sides of the Wave Port sheet are being analyzed. Perhaps the Wave Port is placed inside the analysis space.
Select the menu option File > Open Examplex..., and check whether the Wave Port is placed on the boundary surface of the analysis space in HFSS designs such as '5G_SIW_Aperture_Antenna.aedt' under HFSS > Antennas, specifically in designs like '1_SIW Feed Structure' or '2_SIW Feed Structure + 3Dcomp antenna'.
3487
1057
1051
945
917
