Electronics
Electronics
Creating a PL-258 connector
    • Joaquin
      Good morning, I'm just getting started with Ansys and wanted to create a PL-258 connector since I couldn't find one in the library. However, during the process, I'm experiencing a single error: "Parts XXX and YYY intersect." What's the cause or how can I fix it? My ultimate goal is to simulate a marine VHF antenna with its connector attached.
    • Takeshi Itadani
      It appears that the “BASE_CONECTOR” component and the “VIVO_RF_1” component are interfering with each other. Try deleting the interfering parts of the two components using the Subtract command.
      Also, select the HFSS > Design Settings... menu, and check Enable material override in the Set Material Override tab.
