LS Dyna
LS Dyna
Creating a deformable behavior on Remote displacement – (Explicit Dynamics)
    • kc644
      Hey Guys,
      I'm trying to simulate a y section geometry (Shell model) of an aluminium honeycomb core. However, when I looked on the remote displacement - I can only set the behavior as rigid. I need the geometry to deform like how it occurs in a quasi static test.
      Is there any workaround to this.
      I have done nodal displacements on the edges of the geometry, but that function doesn't allow me to input values for the degrees of freedom on the rotational.
      Y section geometry Remote displacement details
      Hope someone can help me out.
      Many thanks,
      Kiran
    • Wenlong
      Hi Kiran,
      Yes, you are right. Remote displacement in Explicit Dynamics can only have "rigid" behavior.
      You can assign a "fixed rotation" to the end to control the Rotation Y and Z, and a "displacement" to control the X-displacement.
      Wenlong
    • kc644
      Thank you for that. It works exactly how I need it to do.
      Kiran
  • The topic ‘Creating a deformable behavior on Remote displacement – (Explicit Dynamics)’ is closed to new replies.
