March 16, 2020 at 6:25 pm
yazk
SubscriberHello dear friends,
I have imported a CAD model to ANSYS Workbench from Solidworks for a static structural analysis. I would like to apply a line force to the body as shown in the picture below. However, I am not sure how to make the construction line to apply my force or any other way that works.
Thank you for your help.
March 17, 2020 at 1:24 pm
peteroznewman
SubscriberWhat is the source of this force? If it is the weight of the pipe and the fluid inside, you can add a line body or a solid body on the inside to represent the fluid and then turn on Gravity.
March 17, 2020 at 6:18 pm
yazk
SubscriberHi Peter,
Thank you for your response. Actually the line is in the outer surface of the pipe and representing the line contact of the pipe - clamp and as if the clamp apply a contact load force to the pipe. Also, I made a line body in SpaceClaim, however it does not show the line in the Ansys workbench.
Thank you,
March 20, 2020 at 5:08 pm
Aniket
Forum ModeratorUse Project tool in Intersect group of tools on the Design ribbon to take an imprint of the curve on the Solid.
March 23, 2020 at 4:18 pm
yazk
SubscriberThank you Aniket for your response. That works well.
Best,
March 24, 2020 at 7:29 am
Aniket
Forum Moderatorplease mark the post as solution if it answered your question.
- The topic ‘Creating a construction line on a body to apply force’ is closed to new replies.
- FSAE CFD – Lesson 1 Preparation question (Using Discovery)
- Add-in Error Excel
- Missing SubDivWrapper.dll
3927
1414
1256
1118
1015
