TAGGED: designmodeler, mechanical-apdl, model, pattern, preprocessing
June 1, 2022 at 9:19 am
tim.hertinger
SubscriberHi guys,
I´ve got a question regarding my current model in PyANSYS:
I want to model a tapared roller bearing including rollers, inner ring and outer ring. I have modeled both rings and one roller.
Now I want to copy that one roller by creating a pattern of a defined angle. Therefore, I want to create the other 15 rollers by a pattern, without modelling each individual roller.
I know there is the VGEN command that creates additional volumes from a pattern of volumes.
But how can I implement an angle instead of x- and y-coordinates.
Thank you for your help!
Best regards,
herttim
July 6, 2022 at 3:11 pm
Aniket
Forum Moderatorwouldn't that be based on the conversion of polar coordinate system to the cartesian coordinate system?
- The topic ‘Create Volume by given pattern’ is closed to new replies.
Ansys Innovation Space
- CONVERTING STL FILE IN TO SOLID
- The meshing algorithm cannot find matching topology
- Assiging one parameter as thinkness of few shell objects
- [ANSYS Meshing] how to activate curvature for a sizing in a script?
- How do I fix this irregular face meshing problem?
- ICEM O grid mesh for sloped pipe
- How to create a mapped mesh in a chain link model with stud.
- what is the best way to apply shear stress to a shell 181 element?
- Meshing Help – I keep getting errors. How would you tackle this geometry?
918
599
591
483
