July 21, 2021 at 4:51 pm
neilmuir
SubscriberI am trying to visualize the impact locations of particles on a selected wall boundary. The goal is to be able to compile the results of multiple steady-state particle injections together to visualize where the particles land. Any help would be appreciated, thanks.
July 22, 2021 at 9:23 amRob
Forum ModeratorThe easiest way will be to (ab)use the accretion model. From there you'd need a UDF to add a particle strike into a wall User Defined Memory, that's not as easy but there may be an example in the documentation.
Viewing 1 reply thread- The topic ‘Create plot of DPM particle surface impacts’ is closed to new replies.
