Create deformed geometry and compare deformed geometry with original
    • Hiren369
      I have done static structural using ansys student version workbench in which i have given temperature to one material..and total 3 materials are deformed by that...
      Now i have to compare my deformed part with original part..how to measure dimensions of deformed part.
      Use a Deformation plot.  That will color code the amount of deformation relative to the original undeformed geometry.
    • Hiren369
      i have to superimpose two original geometry with deformed. so how i can export deformed geometry
    • parkersheaffer
      You can export the deformed geometry as an stl.
  • The topic ‘Create deformed geometry and compare deformed geometry with original’ is closed to new replies.
