March 19, 2024 at 1:21 pm
Fredrik Solenberg
SubscriberWe are having problem that when creating an empty drawing sheet on assemblys this sometimes take forever... I am talking like 30min-1 hour with just an hour glass on the screen. This is not consistant... but a restart of the computer usually solves the problem.
do you have some suggestings were we should start to find the solution for this?
March 20, 2024 at 6:47 am
Charudatta Bandgar
SubscriberHello Fredrik,
Is this specific to this file, or you are seeing this with all the files? Also, is the file size large?
Regards
March 20, 2024 at 8:01 am
Fredrik Solenberg
SubscriberNo..this can happen any time. When I am talking about an assembly...we are talking about a 250Mb large file. BUT this can also happen on smaller files.Â
March 20, 2024 at 8:06 am
Charudatta Bandgar
SubscriberSometimes larger assemblies could take time to work with, although this is too excessive. Can you try reinstalling SC? See if that helps, either it could be an issue with the installation.
Or clear the temp folder (run %temp%), and see if that helps.Â
Regards.
- The topic ‘Create an empty drawing sheet takes forever sometimes…’ is closed to new replies.
5669
1890
1419
1304
