3D Design
3D Design
Create a wall definition and outlet definition on the same surface
    • atulsingh92
      Hello all,
      In Design modeller, I have the following
      here, the green should be a wall condition while the two rectangles in yellow should be an outlet condition ( or Named selection).
      When I select the 2 yellow and define them as outlets, than it is allright, but then I want to select the green surface minus the two yellow rectangles and then define them as wall.
      How can I do that?
    • Keyur Kanade
      You need to split the surface. Please check under Tools - Split FacenPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
  • The topic ‘Create a wall definition and outlet definition on the same surface’ is closed to new replies.
