3D Design
3D Design
Create a conical hole using an angle specification and the pull function.
    • christian.lachner
      Creating a conical shape with an angle specification is no problem; it works with the pull function. Unfortunately, this doesn't work for a hole.
      Does anyone have an idea how I can create a conical hole with an angle specification?
    • Devendra Badgujar
      Hello Christian,
      Please follow the steps below to create a conical hole:
      First create a sketch like with specific angle:
      Then use revolve about an axis for that surface (cut option) it will create a cone:
      Devendra
