January 8, 2025 at 9:02 am
Webster
SubscriberHello community,
When I was running a FSI simulation (Transient Structural and Fluent), the following error message were echoed from Transient Structural module:
=========================================================== Â
*** ERROR *** Â Â Â Â Â Â Â Â Â Â Â Â Â CP = Â 67653.844 Â TIME= 08:21:24
 There is not enough memory for the Distributed Sparse Matrix Solver to Â
 proceed.  This error has occurred on the process with MPI Rank ID = 10 Â
 on machine (ce-bg112).  Please increase the virtual memory on your   Â
 system and/or increase the work space memory and rerun the solver.   Â
 The memory currently allocated by this process = 376 GB.  The memory  Â
 allocation attempted = 0 GB.  The largest block of memory allocated by Â
 this process that is available for the Distributed Sparse Matrix    Â
 Solver = 0 GB.===========================================================                             Â
A few facts:
- I believe I have prescribed sufficient constraints to my model, and I attemped to reduce the number of elements.Â
- There is no problem when running structural analysis alone.
- The error message could raise at any points during my simulations (e.g., 36%, 41%, 50%) - seems that it is just random, but I cannot say this for certain.
I was confused by the memory of 376 GB allocated to the process - how can this be possible? Thanks.
January 8, 2025 at 4:00 pm
dlooman
Ansys EmployeeAre you using parallel processing with a large number of processors? It sounds like memory used for previous iterations is not being released.
January 8, 2025 at 8:29 pm
Webster
SubscriberThank you for your reply. I am using 20 cores on a single local workstation. And yes, it looks like the momory from the previous iterations is buffered somewhere, could you please suggest me how to give a fix? Thanks.
January 9, 2025 at 2:31 pm
Gary_S
Ansys EmployeeUnreasonable memory allocations are because the model is moving in space. It may also be rotating or oscillating.Â
Add additional supports or suppress parts until you find the issue.
5899
1306
