May 26, 2024 at 3:04 pm
ran soffer
SubscriberHello, people. I have the mash, as you can see in the image. My area of interest is very dense, but it makes it hard to get an average distance at the entrance and exit of the tunnel. I tried to detach some parts to create some of the structural mash, but I couldn't make it work fluent (creating walls). Do you have any idea how to love it? and if not structure how I use unstructured that loog like a good graditn and not like 4 connections?
May 27, 2024 at 6:46 am
Keyur Kanade
Ansys EmployeeAfter detaching if you want conformal mesh then you will need to use Share Topology in Design Modeler or SpaceClaim and then bring it in meshing.Â
Please go through help manual for more detailsÂ
If you do not use share option then you will need to use non conformal approach in fluent. You will need to define interface for those faces and proceed.Â
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
- The topic ‘crating structure mash from danse to undens in ansys mashing’ is closed to new replies.
