July 20, 2024 at 3:51 pm
david.bacci
SubscriberHi all. I use a dynamic mesh (remeshing+smoothing) using a 6dof model, the sover density-based. Mach number is 1.2
Upon starting the simulation I get an error which prompt fluent crash
Updating mesh at time level N...Warning: could not obtain managed tmp svar.All managed tmp svar status:Type 1:Â Free:Â Â managed-rtmp2 1 remesh_driver_impl.c:5644Â Â managed-rtmp3 1 remesh_driver_impl.c:5641Â Â managed-rtmp1 0 :0Â Â managed-rtmp0 0 :0Â Used:Â Â managed-rtmp4 1 remesh_driver_impl.c:6717ÂType 3:Â Free:Â Â managed-itmp3 0 :0Â Â managed-itmp2 0 :0Â Â managed-itmp1 0 :0Â Â managed-itmp0 0 :0Â Used:Â Â managed-itmp5 2 cavity_agglomerator_impl.c:4365Â Â managed-itmp4 3 cavity_agglomerator_impl.c:4359Â Â managed-itmp6 1 remesh_driver_impl.c:6703Â Â managed-itmp7 1 remesh.c:144Â Â managed-itmp8 1 remesh.c:137ÂType 6:Â Free:Â Â managed-tmpobjp2 1 boundary_layer.c:877Â Â managed-tmpobjp1 0 :0Â Â managed-tmpobjp0 0 :0Â Used:ÂType 9:Â Free:Â Â managed-ndtmp1 0 :0Â Â managed-ndtmp0 0 :0Â Used:ÂType 11:Â Free:Â Â managed-nd3tmp0 0 :0Â Used:ÂType 12:Â Free:Â Â managed-nd-ndtmp1 0 :0Â Â managed-nd-ndtmp0 0 :0Â Used:ÂType 45:Â Free:Â Used:Â Â managed-tmpunion0 3 cavity_agglomerator_impl.c:4352Â Â managed-tmpunion1 1 remesh.c:126Â Â managed-tmpunion2 2 remesh.c:119Â Â managed-tmpunion3 2 rp_recon.c:23762ÂType 56:Â Free:Â Â managed-tmpindex1 0 :0Â Â managed-tmpindex0 0 :0Â Used:ÂError at Node 0:Unable to allocate sv_objp_tmp2Any suggestion? For some strange reasons the same case with the same udf it works with the pressure based solver in transonic
Best
David
July 22, 2024 at 6:15 pm
Federico
Ansys EmployeeHello,Â
have you tested your case with density-based solver but without Dynamic Mesh?
We should determine if DM is the issue or something else in the case.
- The topic ‘Crash Using Dynamic Mesh’ is closed to new replies.
