3D Design
3D Design
Crash by using Script Editor
    • Fabian Scr
      Have anyone the same problem the Spaceclaim crash by using Script Editor? Or have anyone a Fix?
    • Devendra Badgujar
      Hello Fabian,
      Do you face this issue with any specific model or even with simple model created in SpaceClaim?
      It could be beneficial to reset the user settings from SpaceClaim Options > Advanced > Reset All User Settings.
      The main thing we recommend in this type of situation is to make sure the drivers for the graphics card are up to date.
      Make sure to go directly to the card manufacturer's website to check for the latest version.
      Devendra
      • Fabian Scr
        Its every (by Start Click (no Model) or with Simple Model
        I Have Reset All user Settings and the Driver is Up to date :-(
    • mjmiddle
      Does it crash when you open the script editor or when running your script? Your script may do something invalid with the current model.
      You can also try running in "run" mode. The debug mode runs in a different thread, allowing you to click in the model window while it runs and possibly confusing the script. Click the pulldown by the right-pointing triangle at the upper right of the script editor, and choose "Run." Then use that same green triangle to run the script:
    • Fabian Scr
      Crash by Click the Button Script Editor or the Button Block i can not Open the Editor
    • mjmiddle
      Sounds like running on some unsupported configuration. Maybe the operating system build or remote display software.
    • Fabian Scr
      Is the Newest Build from Windows 11, the Newest Driver from Nvidia and have No Remote Display Installed
    • mjmiddle
      Check against tested graphics cards for 2024 R2:
      https://www.ansys.com/content/dam/it-solutions/platform-support/2024-r2/ansys-2024-r2-graphical-display-graphics-cards-tested.pdf
      Also, try deleting or renaming these while SpaceClaim is closed to return to default settings:
      %APPDATA%\Ansys\v{version}
      %APPDATA%\SpaceClaim
      %APPDATA%\..\Local\SpaceClaim
      If you can't figure it out, try reinstalling.
      • Fabian Scr
        i have now try delete all Spaceclaim and Ansys Folder
        And Reinstall de Spaceclaim 2024 R1 and Try the Older SpaceClaim 2023 R1 and is the same Result!
        Spaceclaim 2023 and Spaceclaim 2024 Crash by Klick the Script or Block Recording
Viewing 6 reply threads
