January 29, 2024 at 6:17 pm
Zander Fut
SubscriberHi,Â
I'm working on a crack growth analysis and facing an error which prevents the simulation from running. Initially I was using my university's Ansys but had to move to a free student version on my personal computer due to write access related errors which would be difficult to solve on the university's systems. I was able to run the static crack growth simulation on the university software, but now when I try to solve it on my free student version, I'm facing an error stating:
NUMBER OF PARAMETERS 4 FOR CGCR TABLE FOR MATERIAL 1 CANNOT EXCEED 2
I believe the CGCR refers to crack-growth fracture criterion but other than that I'm unclear what this error means and I was unable to find any information about this online. Anyone have any ideas how to work around this?
Thank you.
January 30, 2024 at 6:30 pm
David Weed
Ansys EmployeeHi,
Can you show me the commands you're using to initialize the material model? There's a chance that one of the fields is off.
January 31, 2024 at 3:35 pm
ferdinand.doemling
SubscriberÂ
I think this is a localisation problem. Workbench / Mechanical does not convert decimal and thousands separators correctly.Â
Here is a screenshot from one of my DS.DAT files.
My system language is German. This problem first occurred in 2024R1. The corresponding workbench file was created in 2023R2.Edit:
From the engineering data component in a fresh 2024R1 wbpj.
February 5, 2024 at 6:26 pm
Zander Fut
SubscriberI think this was the issue here. I remade the model in the free student version, which is a 2024R1, compared to a 2021 version used in the university and the error is now gone.Â
February 6, 2024 at 7:01 pm
Zander Fut
Subscriber-
February 7, 2024 at 8:25 am
ferdinand.doemling
SubscriberÂ
rather ugly hotfix: change the decimal seperator to point in your language & region settings on your machine. That’s what I have done. Fixed the issue for me.
From another post (how-to-set-a-comma-as-the-decimal-separator-in-scdm): "The symbol used for a decimal separator (point or comma) is controlled by the Windows system settings". I don't know if this also applies to all other Workbench related applications, but I have not seen any other setting that suggests otherwise.
Additional Info: I use a windows machine for some simulations, mainly because of SpaceClaim.ÂÂ
February 7, 2024 at 4:16 pm
Zander Fut
SubscriberThis actually worked, thank you!
- The topic ‘Crack growth analysis CGCR table error’ is closed to new replies.
6810
1343
1152
