TAGGED: -waveguide, characteristic-impedance, coplanar, hfss, high-frequencies, microwave
April 22, 2024 at 6:45 pm
dimolina
SubscriberTo analyze the parameters of a coplanar waveguide that operates in microwave frequency, I have to simulate the S parameters and measure the CPW characteristic impedance. The S parameters I didn't have any problem and also I made a tutorial to simulate those for my team in Brazil, link in the end of this post.
However, my main intention is to determine the characteristic impedance of the CPW. How can I get the characteristic impedance using the S parameters? Or ANSYS HFSS have some tool that can simulate the characteristic impedance direct to some coplanar waveguide?
Thanks for the help!
https://www.youtube.com/watch?v=Vwps9U_NypA&t=10s&ab_channel=DiegoMolina
April 23, 2024 at 10:22 pm
Stefano R
SubscriberUnder the results option, you can plot Port Z0 to get the characteristic impedance. Make sure it is not renormalized under Excitations.
April 26, 2024 at 11:59 am
dushyant.marathe
Ansys EmployeeHi Diego
If you are simulating the CPW line and having wave ports as exciation, you can determine the characteristic impedance. You make sure that you have defined an integration line while creating the waveports, as characteristic impedances like Zpv or Zvi are not calculated by default in HFSS.
After simulation, you can plot the Port Z0 from Results.
Thanks,
May 10, 2024 at 4:09 am
dimolina
SubscriberHi DMARATHE, thanks for the help.
I usually make terminal wave port excitations to simulate the S parameters. When you said to define an integration line, did you mean to make a modal wave port for my port excitations? If it is, how I build correctly for cpw line the line for the integration line?
May 14, 2024 at 8:26 am
Maurice Will
SubscriberIn the “Results” option, you can greenleafguru plot Port Z0 to obtain the characteristic impedance. Ensure herbalhighsociety it is not renormalized under “Excitations.”
September 23, 2024 at 9:10 pm
maryam.rahmani
SubscriberI have same issue. I have been trying different port defenision and I get different values for characteristic impedance which are way far from the value calculated by different cpw calculators. I have used terminal wave port with setting the center conductor as terminal, I have used Modal waveport by drawing line from the side ground-plane to the center conductor, I even have tried using terminal wave port by setting the center conductor as reference and set the Differencial pair and common pair ports. I still keep getting different values with different port defenision and the most important the results are completely off from my calculation (as long as online calculators) which I am pretty sure that my calculation is correct. I really appreciate if anyone can help me with that. Strugelling with this for a couple of weeks!!! Thanks!
- The topic ‘CPW resonant frequency HFSS Simulation’ is closed to new replies.
6790
1332
1152
