November 15, 2023 at 8:41 pm
Eli Couture
SubscriberHi. I'm trying to feed energy into the resonator via the coxial feed line. The cavity resonates at 28 GHz. The coxial feed is flush against the resonator. There is no space between the PEC feed lines. The results indicate that all the energy is being immediately reflected. I feel as though theres a simple solution but I have yet to find it.
November 20, 2023 at 9:22 am
Vaggelis Sidopoulos
Ansys EmployeeHello Eli,
As I can see from the model, you are using vacuum and PEC as the only materials for the objects. HFSS will also enclose all the objects with PEC. This means that there are no losses in your model and all of the energy that isn't stored in the cavity will be reflected back. Also, your cavity doesn't have any resistive properties, which in turn makes the Q of the cavity very very large, meaning the resonances will be very sharp and with an extremely narrow BW.
The results you are observing are most likely due to the interpolating sweep's accuracy. You can try increasing the Sweep points, as well as the Error Tolerance of the Interpolation, in the Interpolation tab of the Sweep.
If you'd like HFSS to solve for every single point of your sweep, you can try the Discrete Sweep as an option that will also give extremely accurate results.
As a suggestion, you can always plot the VSWR and see the very sharp resonacnes.Finally, try using an actual conductive material, like copper, for your cavity, you will be able to observe all of it's properties very clearly.
Hope this helps!
Best Regards,
Vaggelis
- The topic ‘Coxial Feed into Cavity’ is closed to new replies.
5779
