March 27, 2020 at 9:30 am
DanW
SubscriberIs it possible to include PMLs for 2 different materials (2 fluids, or 1 fluid/1 solid) to model time-harmonic acoustic scattering in a Harmonic Acoustics model. Conceptually I would like to model a semi-infinite fluid-fluid or fluid-solid interface with a finite sized scattering feature embedded in the interface. In this case I need two PMLs to terminate each medium which then also contact/couple to one another at the interface (see sketch below). It would appear that pressure or FSI coupling on these surfaces doesn't stop edge reflections on the interface (I think may require a special PML formulation).
March 30, 2020 at 5:51 pm
ErKo
Ansys EmployeePML is for acoustic elements only - there is no PML BC for solid elements (say soild186).
March 31, 2020 at 6:47 am
DanW
SubscriberThank you very much for your reply. Understood - I was able to set a solid physics region to a PML-type without causing any obvious errors in ANSYS, hence my (erroneous) assumption that elastic PMLs were available.
In the case of a semi-infinite fluid-fluid interface, is it possible then to have two PML regions which contact/couple with one another?, as in the figure above (both upper and lower mediums being fluids).Â
Thank you again for your help.
- The topic ‘Coupling PMLs for semi-infinite fluid-fluid or fluid-solid interface’ is closed to new replies.
- optiSLang: general question about output variables & expressions
- Keeping concentration same for different sized particles in discrete phase model
- 3-Way System Coupling (Thermal-Structural-Fluid)
- optiSLang & AEDT Optimetrics: response variable has value of 0
- Thermal Desktop: Running RadCAD and SINDA outside of AutoCAD
4888
1587
1386
1242
