August 11, 2023 at 9:02 am
Maximilian Wohner
SubscriberI want to couple the following behaviour:
Mechanical generates a mechanical deformation, and at the same time, a body force is calculated in Maxwell 3d based on the Lorentz force (Conductor deformation and, as a result, other the current density). This behaviour should be generated iteratively per time unit.
I would like to do this in Workbench and it could be a two way coupling.The shown figure isn't possible.
Hope you can help me and thanks a lot for your help.
MaxÂ
August 11, 2023 at 5:14 pm
GLUO
Ansys EmployeeÂ
Maxwell Mechanical 2-way coupling for small deformation is done through a feedback iterator.
GL
- The topic ‘Coupling mechanics and Maxwell 3D’ is closed to new replies.
