Photonics
Photonics
Coupling length measurement
    • dubey
      Hi, I want to study the coupling length vs radius of the ring and coupling length vs the coupling efficiency from the bus to ring waveguide (see attached figure). The structure I want to try is with simple bus bent bus and racetrack ring resonator. Can you please suggest the best way to measure the coupling length in this structure? Thank you!
    • Guilin Sun
      This is doable via FDTD, and possibly with FDE's help to get the proper sweep range.
      I would suggest that you first create the two waveguides (ring and the straight ) in FDE, and set proper bending radius accordingly. Then you can estimate the coupling length when you simulate the modes for the two waveguides separately, where delta_n is the difference of the neff for the two modes. You can also estimate the couling efficiency after you copy one of the modes to the global deck with overlap.
      In FDTD, you can simulate part of the ring with the straight "bent" waveguide with titled ports inside the ring, and sweep the gap/arc length.
      As for the coupling length measurement, you may define the arc length of the straight wavefuide. It is up to use for the definition.
  • The topic ‘Coupling length measurement’ is closed to new replies.
